if you have a car just buy a second identical battery and swop them round every week or sooner if reuired this will stop all the worries of dammaging the batteries
you may have to additionaly charge the batteries dependant on how long your car runs are ect
you would also have to check if frequent battery changing will compromise the electronics on your car
Normal AA cells are not NiCd, but you can get NiCd cells in AAA, AA, C, D etc sizes.
They'd not be my first choice, as they aren't the smartest technology on the block now - NiMh would be better, Li-ion better still, but they're hard to find in genuine C&D sizes, and the chargers are expensive.
I've followed a couple of threads on this site re: the above but i'm afraid my limited electrical understanding means i get lost the first time someone mentions inverters or any kind of tech speak!
I have just acquired a standard sized rented garage - not powered and no option to run a generator. The previous occupier had rigged up a 'sneaky' fluorescent lighting system spurred from an external power source (a exterior general public area light). Obviously the council got wind of this and disconnected his set up, but left all the lighting in place inside the garage.
So, my question to you knowledgable folk - could i use the light set up already in there (3 x 4 foot fluorescent lamps) and power those from a car battery?
If so, but need additional items (inverter)? would someone be able to list a easy to follow shopping list and setup to use.
If not able to use the existing lighting set up, would someone be able to again list an easy to follow set up guide and shopping list?
