I'm currently renovating a house and the next job is to send power out to what will be a small dog grooming salon.
At the moment we live in rented property, the salon is run off a length of 2.5 twin and earth running off a socket in the kitchen, this goes to a fusebox in the salon. I know this isn't ideal but was a temporary solution because it was rented. In the 4 years it's been set up surprisingly its never tripped once, even with all the damp in the building due to dogs being washed and dried!
The new set up will be done properly as its going to be a permanent fixture in a house we own. The salon will be about 25 meters from the house, cables will be run in 4in waste pipe laid at a depth of about 1m. Due to the solid structure of the 4in pipe, do I need to use armoured cable or would 10mm 3 core be ok. At no point from the house to the salon would the cable not be in the 4in pipe. This time the cable will be connected to the house fuse box and not off the back of a socket!
Any advice would be appreciated.
