Running wire threw kingspan from loft to socket
Status
Not open for further replies.
13 Feb 2011
Running wire down kingspan Is it ok how i've done it?
I am running wire's from my loft down to the sitting room, i have 100mm of kingspan between joists and 25mm kingspan over the studs then plaster board, i am cut a 60mm inch wide channel kingspan right threw the 25mm kingspan and then duct taped it so wire's cant touch kingspan. then i put the plasterboard on after it,
I am only running the wire's, i am not conneting them
if this is not ok how can i do it??????
Status
