M
Mickymoody
As long as the 2200 micro farad is good, overrating them is even better. Why the manufacturers use the bare minimum is strange? Obviously costs.
Nice one.
Nice one.
Actually, that's slightly worrying. In my experience, better (more reliable) capacitors will always be larger - especially if they have a higher voltage rating or capacitance. Your Maplin capacitors may not last long.The new capacitors are higher voltage but physically smaller than the originals.
See http://www.satcure.co.uk/accs/television_capacitors.htm[/QUOTE]
Not necessarily, the manufacturers go for what is cheap, if the new caps have a better voltage rating, and a better temp rating, and therefore a better ESR, they would be OK. Larger caps might be used because they are older technology, and cheaper. As the new caps are higer rated, they will run cooler anyways, thus be more effective. So for me, size does not necessarily matter, as long as the specs are good. So says the ladiez.![]()
Fair comment. So what is the ESR of the Maplin capacitor?
Maplin should know. If a seller can't provide the ESR value then it's likely that it's high, meaning that it's a "general purpose" electrolytic, which may not last long in a switch mode PSU. Typically, the value will be 0.03 Ohms or lower at 100kHz.
The problem with using incorrect capacitors is that the PSU may appear to function perfectly at first but you may notice a little interference on the picture, which gradually becomes worse. This occurs because a capacitor with too high an ESR allows short-duration high-voltage spikes to escape on the "DC" supply lines, causing the interference. The picture can be affected in different ways, including a slight "graininess". The interference can also be superimposed on the tuning voltage, causing problems with tuning and some quite weird effects.
The capacitors will run warm, or even quite hot to the touch, and the problems will become worse.
There's a good article about ESR here:
http://members.ozemail.com.au/~bobpar/esrtext.htm
ESR is quite simple, by the way. It's just the impedance of the capacitor, which is usually measured at 100kHz for convenience. "Effective Series Resistance" is just a fancy term used to describe it.
