Fix was to put that little thermal cut off device in the freezer. If the oven has overheated it will continue to cut off the electricity even when the temperature is back to normal.
Anyway thought I would simplify the how to for this:
1. Turn off power supply to oven at the fuse box so you don't electrocute yourself.
2. Pull out the oven from whatever fitting you have it in. This is easier with two people.
3. From the top of the oven remove the covering metal. The top it split into two panels one above the dials and one at the back. You need to remove the one at the front. There are two screws holding it in place about half way back.
4. Once you have the cover off you will see something like the second image in the original post.
5. The big black thing with the copper coil on it is a fan. Below that on the slope of metal is the thermostat/cut off device. Its a black circular device with two long white plugs coming out of the left and the right of it. You can see it in the second image above.
6. Take the two white plugs out of the device and unscrew it.
7. put the device in the freezer. I put it in for about an hour
8. Put the device back, plug it back in, screw the top front cover back on, put the oven back in its fitting and turn power back on
9. If you are lucky the time will come on again.
Hope this helps someone. Seems like a common problem. Got two questions if anyone is ever back this way: Does anyone know why the oven overheats at all? Also does anyone know why putting the thermostat in the freezer "resets" it?
Cheers
Robert
Cheers
Robert
