So the company did not send an engineer as booked, presumaably because I suggested I wouldn't pay their £75 call-out fee if the problem originated with their initial work.
Freesat was working again... till this evening. Now again showing 'no signal'.
I've found the 'signal strength' (100%) and 'signal quality' (100%), but despit this 'no signal'.
LNB power shows green (on) and DISEqC (whatever that is!) is off. Unicable (?) is off. If I turn it on, signal strength and quality go to 0%
I'll try again tomorrow to get them out, but failing that will write and tell them I'm getting someone else and will send them the invoice.
If it was their fault I'll happily take it to court if they're not prepared to take responsibilioty.....
oops edit: signel strength and qua;ity now zero agaon....
