Scantronic 9450
Thanks for the reply..yep it is pretty simple.
But the install guide only mentions the codes for zone 2..
How about the others?
Most be some better paperwork out there..just don’t wanna feck it up..lol
You can’t program the zones fully ...!
Thanks for the replies guys..think I am getting somewhere..
The manual only mentions zone 2 as far a programming.. what about if I want to use zone 1 or 3 as entry ..there are no mention of them?
Or is zone 2 the only zone you can have options on.
Maybe I’ve got to change the hard wiring to move my entry zone ?
this is correct
What I am trying to do is change the entry zone on a temporary basis and swap back again at a later date but I dont want to have to keep rewiring it.
Now I have sussed out how it works I could I can use zone 2 as the other enrtry point seeing as it has a door contact and program entry/exit as per the instructions.
But what happens to the "true entry" point?
I will still want to use the entry point enter/exit door but would prefer it to go straight into alarm but presume by defualt it will behave as before ?
Yes sparky is correct Zone2 can only be an entry ROUTE or Alarm not a entry/exit
Ahha ..we are getting somewhere with this.
It might still work.
In the user guide it gives codes for entry and exit times..I presume they are obviously for the entry /exit door..thats ok
But what about zone 2 there a program option of ENTRY time or is there a default?
FFS .....you can’t use zone 2 for ENTRY ...it a zone that you CAN allow to be walked passed when you open the ENTRY zone ....you will have to wire both doors to the Entry exit zone ...
