I thought that poor MichaelTTs thread had been hijacked enough - so I thought I'd post this in a new one.
Let's get into the spirit of DIY (and the ridiculous)
For all you DIYers, here's how to save yourself a fortune.
You have a 4 bedroom detached house with attached garage and utility rooms and outbuilding.
Wiring dating mainly from the 50s, but the board has been upgraded to a split-load 12 way - RCD protecting roughly half the circuits - none on the rest. CU in the garage.
Taking Scedule 4 literally, here's how to rewire it youself, without notifying, and save yourself possibly thousands.
Circuits:
1/ 40A MCB Shower
2/ 32A MCB Upstairs sockets
3/ 32A MCB Downstairs Sockets and FCU feed to outhouse supplying power and lighting
4/ 20A MCB Garage Socket Radial
5/ 20A MCB Utility Socket Radial
6/ 6A MCB Upstairs Lights
7/ 6A MCB Downstairs Lights
8/ 6A MCB Garage and Utility Lighting
9/ 40A mcb Cooker
10/ Kitchen Ring Final
11/ Kitchen Lighting
12/ Spare
Ignore circuits 1, 9, 10 & 11 - These are special locations and would require notification.
For socket circuits 2 & 3 - run a 500mm length of 4mm T&E from each MCB to a surface mounted, single socket outlet (for each circuit).
This is classed as a 'spur' and is not notifiable.
For socket circuits 4 & 5, run a 500mm length of 2.5mm T&E from each MCB to a surface mounted, single socket outlet each.
These are also classed as spurs.
For each lighting circuit, run a 500mm length of 1.5mm T&E from each MCB to a batten lamp holder each.
You're getting the idea now, aren't you?
That's enough for one day - have a break.
The next day you can set about stage two - destroying half of your house!
Remove the existing '50s wiring from each MCB, leaving the spurs that you added in place.......still okay under Schedule 4 - it doesn't say anything about removing circuits.
The spurs that you added yesterday, have, by default, become radial circuits today.
Rip old wiring and all old accesories out from your house.
Mark out where you'ld like all your nice new socket outlets, switches, lamp holders etc.
Chase out any walls etc etc
Now, remember the spurs from yesterday.
Starting with Circuit number 3, the downstairs sockets, get your roll of 4mm T&E and run the cable from the single socket outlet (that you installed yesterday) to each of your downstairs socket points - you get the idea. Don't forget to run the new 2.5mm cable to your outbuilding from your new FCU.
Again, not notifiable, you are only extending a circuit and adding socket outlets to it.
Apply the same procedure to each of the other circuits.
At the end of this procedure you will have succeeded in rewiring most of the cable in your house, you will have added all new accessories, and all as a DIY project and not notifiable (According to Schedule 4).
You could at this point remove the socket outlets and batten lighting that you installed on day 1 and join the cables together by whatever method. (You're not going to want all those lights and sockets around your CU.)
Now, the important bit.......DON'T re-energise the installation at this point.
Although this is a DIY project, the circuits still require the necessary testing before and after energising.
Here's what you do next:
Employ an Electrician who is a member of one of the self-certification schemes.
Tell him you want a new circuit installing for both your shower & cooker and that you want new power and lighting installing in your kitchen and lighting in the bathroom.
Tell him you'd also like a new dual RCD board installing.
You should get that little lot for less than a thousand pound - but the big bonus is........he's gonna test all your circuits for you before re-energising the new CU AND give you a schedule of test results for your circuits.
And there you have it, a full rewire for less than half the price
Now isn't that bloody ridiculous!!
And you're telling me that we shouldn't try to interpret what Schedule 4 is implying - we should just take it as read???
Circuits:
1/ 40A MCB Shower
9/ 40A mcb Cooker
12/ Spare
