Screeching Hoover tumble dryer
26 Jun 2004
Hi
I have a Hoover condenser tumble dryer. It is about 2 years old.
During the tumble it creates a loud screeching/ squealing noise.
Thought this might be the belt but a noodle around the interweb suggests it may be the Idler pulley bearing burnt out.
Does anyone know if Is this a replacement that is easy to carry out?
Sorry. Not done one.
Depending on where the noise is coming from. It might be worth your while having a look to see if you can gain access to the jockey pulleys. Apply a spot of oil on the pulley shafts and see if that quietens things down.
Oil needs to be applied to the pulley shaft--not the belt, or where the belt runs on the pulleys--
The jockey pulleys are located at the bottom by the motor, if that's any help
