What have pipes got to do with it?
Dunno you tell me.
Use two parallel pipes or batons as guides to level the dust or sand.
Dunno you tell me.
What have pipes got to do with laying block paving?
This is a how a pro does it...
http://www.youtube.com/watch?v=PwSIkkZVBaA[/QUOTE]
Wow, that's amazing.
It's amazing how that "pro" just turned up and all the bedding sand was magically level and even.
Seen an online video with a guy using this pipe method so I get the gist off whats being acheived. But it wouldn't be practical on a large area.
On the large area as in that video you would just use a laser level (preferably with a grading facility) and a bomag roller or large wacker plate.
Hmm yes, ideal advice for a diy forum.On the large area as in that video you would just use a laser level (preferably with a grading facility) and a bomag roller or large wacker plate.
I have also seen tractors used with a rubber muck squeegee for levelling screed sand, but ho hum it is unlikely that Johnny DIY will be laying 10 acres of paving any day soon eh Norconihaventgotaclue.
"Think" - i doubt you have done much of that.Though I think you'll have a run to pipe center for a load of gas pipe to do your levelling.
There is no other way if you want accurate levelled or graded paving, than to use rails to form the level of the bedding.
If you want something like an Alton Towers ride, then yes don't use rails
We don't use screed rails when doing concrete floors either!We level concrete flooring to within 5mm accuracy over vast areas with no screed rails.
Don't see the need for them
Drives don't tend to be level though
I'd use a libalullah vibrating screeder for levelling a sand screed.
5 times faster and compacts the sand as it passes.
Also no need to be faffing around down on your knees trailing a screed board and pipes.
Also no pipe track to fill in afterwards.
You do not put the block pavers down on compacted sand or dust, that is why rails are used on top of the compacted half to dust, once the pavers are down you run a whacker plate with rubber mat over the blocks.
The secret is to have it level.
Does this vibrating screeder provide falls, cambers, curves etc like you would need on a driveway?I'd use a libalullah vibrating screeder for levelling a sand screed.
YesDoes this vibrating screeder provide falls,
cambers,
curves
Is it wieldy i.e. can it be used if the driveway narrows down?
Block paving is usually laid with a sturdy pair of knee pads because most of it is done on your knees.
Is any advice you have given relevant to diyers that are paving driveways?
