SDS -vs- Normal drill
28 Jul 2005
Bristol
Hi Everyone,
I have about £100 odd to spend on a power drill for drilling wood, masonry etc. Not a lot but times are hard.
It will mainly be used for DIY but I may use it on site occasionally so it needs a bit of uumph.
Can anyone recommend a make or model and should I go for SDS rather than normal? Is this the way to go?
Have you considered the weight of an SDS drill, some are 7KG`s.
JonB
For lots of masonry channeling and chiseling i would say SDS+ is best.
Rotary stop allows you to chisel.
a quick change keyless chuck helps versatility as you can use normal drills etc.
At that money try the Bosch PBH240RE i've got one and its a good general purpose drill.
A lesser powered version is PBH2200RE
For lots of wood or steel with a bit of masonry try impact drills like Bosch PSB1000RPE as its a bit easier to handle.
Cordless gives you much greater freedom but less power.
ebay shops have the best prices if you know what you want.
I think you both have a point.
If I was using it everyday then maybe SDS and I would get used to the weight.
Plus I would have to go and buy a big selection of SDS bits as well.
I realise SDS is probably better.
Big selection of SDS bits? If you're doing 2nd fix get a small cassette with 7 or 8 drills in it then buy the rest as and when needed. If you're plugging walls most of your plugs will be 5-6-8mm. A basic SDS drill, like the Bosch GBH2-20SRE or deWalt D25003K weighs in around 2.5kg (hence the 2kg class) - not the ridiculous 7kg quoted by another respondent. I'd recommend getting a machine with rotation stop as you'll then be able to use it for light chiselling later on. The 2kg machines are a bit slow doing that, but the next size-up 3kg machines, like the Bosch GSH3E, are a lot more expensive, but they do drill and chisel a lot faster. I feel that 3.5kg is about the maximum weight most people can hold for doing lots of drilling unless you happen to be King Kong.
Remember, SDS drills can take a conventional 3-jaw chuck in an adapter for drilling wood or metal, although there are firms making SDS metal and wood auger bits as well (they're a bit pricey, though). Another useful low-cost addition is a 6mm hex bit adaptor - to take bits for driving large screws, etc.
Whatever you buy, try to stick with good industrial stuff (Bosch blue, deWalt, Metabo, Milwaukee/AEG/Atlas-Copco, Ryobi, etc) as they last and you'll still be able to get spoares (brushes, bearings, switches, etc) in 3 years time. Buy cheap and you'll probably end up binning it first time it goes wrong.
Scrit
Thanks to you all,
I,ve just ordered the Dewalt D25003k SDS from screwfix. It was on offer at £79.99 reduced from over £130 apparently and comes with a 4 bit set.
This I hope will do me.
Cheers.
just dont get an erbauer fro screwfix... had 2 and both had problems. now have makita and its never let me down
The main downside i find with using an SDS with a 3jaw chuck is it can be a little clumsy, and can be a bit slow for some drilling jobs as they run at a lower speed, around half of the RPM of a normal drill.
I bought an hitachi sds+ from a company called bes plumbing supplies(can order online)- free delivery for abuot £108. Used drill for holes in masonry for soil pipes and have been very impressed with the performance and quality. Breezed through old hard engineering bricks
I agree, HM, but if you only have the money to buy one good drill which do you choose? Nothing beats an SDS hammer with rotation safety for all-round versatility, IMHO. If you want an SDS which can run a conventional chuck without the adaptor, then the one(s) to go for are the Atlas-Copco/AEG (and Milwaukee?) drills with the Fixtec system - however they don't come in cheap. If I'm using an SDS drill for wood bits they're generally big auger bits, so high rptation speed isn't an issue there.
Scrit
Just had the said drill delivered.
Havent used it yet but cant quarrel about the delivery.
Less than 24hours.
