C
confidentincompetent
noseall said:Galena1 said:The nozzle points in the direction that is yet to be filled. What you are trying to do is allow the cut end of the nozzle to do most of the shaping of the sealant for you.
is this the best kept trade secret or do all internal installers do it this way? i have yet to see a upvc monkey do it this way but i guess a welded looking bead is ok for an external window scenario. in other words no finger.
Thats what I thought .. I find pushing method ok on strait runs ie over worktops and erm perfect tiling.. but, if I hit say, an uneven tile, it's more difficult to control, so use the drag method mainly .. guess its what you get used to..
I tried using a wet finger, but the sealant accumulated on my finger. When I tried to reapply the silicon fom my finger into the gap...everthing went pearshaped......the consistancy of the line of sealant was spoilt.
If I do get any on me finger I wipe it off onto a rag, rewet finger, Wipe nozzle before each run. I tend to get the surface of the run wet first by very lightly running a wet finger over, once wet then you can apply a bit more pressure. I use 785 but find if i leave it more than a minute it will have skinned too much
