Security lights from fused spur in loft
Status
Not open for further replies.
Note that I am a DIYer, (so happy for John to correct me)
I think you also need:
A white back box to put your DP switch in:
https://www.screwfix.com/c/electric...m_sp=managedredirect-_-electrical-_-1gbackbox
If your DP switch has a fuse, then change this from a 13A fuse to a 5A fuse.
Presuming that your cable will be outside and exposed to sunlight/UV I would use the following 0.75mm2 cable between the lamps:
https://www.screwfix.com/c/electric...de=3183p&conductorarea=0_75_mm_&sort_by=price
cable clips (above 0.75mm2 cable has a 6.8mm diameter):
https://www.screwfix.com/p/tower-co-axial-cable-clip-7-0mm-black-pack-of-100/14161
You also need to consider how to join the cables and the lamp at the security lamp themselves. Does the lamp have an internal area for this? Or simple a length of cable sticking out of the back?
John , Agreed, not sure why/how but I once manged to get a SP version (possibly becuase I used to buy the cheapest version/brand), and have ever since always double checked to make sure DP.
Decades ago, SP ones did exist (and I may even have some lying around somewhere), but I haven't seen one for many years.
Having said that, before I install any switch I usually check its functioning with a meter - and I did, once, many moons ago, come across a DP switch (can't remember whether it was in an FCU or what) in which one of the poles was 'jammed closed' (can't remember whether it was L or N) - something which would, of course, probably not have been detected if I hadn't checked.
Kind Regards, John
You also need to consider how to join the cables and the lamp at the security lamp themselves. Does the lamp have an internal area for this on simple a length of cable sticking out of the back?
I havent picked the lights yet but if need be I will get external junction boxes. I also want to hook up PIR sensors.
You don’t need a fused spur and they should not be used on a lighting circuit. A 3a fuse will have no discrimination against a 6a MCB. Use a double pole switch.
Some people will argue a FCU is cheaper. That is a cowboys answer. In the scheme of things the additional cost of using the correct component is not significant.
Not "should not" but, rather, "need not" (and won't serve a particularly useful purpose if they are used).
.. in which case I have no problem with being regarded as a cowboy.
In your personal opinion
Please explain why you think a FCU is needed on a lighting circuit.
Please explain why you think anyone other than a “cowboy” would suggest using an incorrect component just because it is very slightly cheaper.
Status
