Don't overthink it, you're just bolting the hinges on. I've got some with coach bolts, some with roofing bolts. You don't need to have bolts in all the screw holes. If somebody wants to break in they could cut the (heavy duty) hinges in seconds with a battery grinder, or cut through the wood
Sure but that would make a considerable amount of noise and hence, attract attention. I appreciate that it's about sensible precautions but I am also interested in the aesthetics as I am building this whole shed from scratch. DIY'ers pride and all that!
I brought the roofing bolts and locking nuts. Couldn’t help myself testing it on a spare piece of wood. Exactly as you said, once on, if someone tries unscrewing, it just spins. The nut does not loosen. Genius!
I am interested to know why a hex bolt would behave differently?
