It's not a strip around the whole edge, you can use less if you do a total of four parallel strips which will divide your floor area into three bays approx 3.0mx3.33 (for a 3mx10m structure) This will give a total of 12m of strip rather than 26m which is a lot less digging and concrete
Since posting I have given the height of the suggested foundation some thought and you could make it lower as follows.
Assuming the level you have now excavated to has removed all topsoil, dig the 4 foundation strips down from this level say 300mm wide by 150mm deep.
These can then be filled with concrete, a couple of lengths of reinforcing bar 2" up from the bottom would do no harm. To get the concrete level hammer some metal or even wood pegs in to the excavation and set the tops of the pegs level with a spirit level & straight edge or a water level. If you then fill the strips with concrete until it comes level with all the pegs.
Again to keep the height down you could lay the blocks flat or even just use a course of bricks. The wickes blocks will be fine.
