So i have found the issue with why i was unable to fit the last circlip.
The triangle bracket on the axle had a crack in it which had then moved using up the end float.
I purchased another mower for £5 yes £5 & swapped the axle over complete with wheels, self propell etc & works like a dream.
Now the wheels tuen as opposed to dragging.
I also had another mower with a carb issue that just wouldnt correct itself for me even when i fitted a new carb.
So i then swapped the engines over & now a 21 inch cut working mower.
