B
breezer
How do you manage to get, for example, the blue Dictionary address into your posting? .
its a hyper link (amaziing what is in forum information)
I don't.bolo said:I agree.no its not.There's a subtle difference - films are disposable and have use-by dates, whereas a memory card is an essential component of the camera that happens to be removable.Richardp said:but its only really like buying a camera without a film.
It's more akin to buying an SLR body without a lens.
And they require a lens, too. (Although no doubt some ar*e will point out that a pinhole camera can still be used to record on a silver halide painted glass plate, and, presumably, processed by a frock-coated gentleman wearing pince-nez and a pained expression).All cameras, digital, 35mm, plate and even polaroid require something on which the image can be recorded.
And digital ones that come with a lens and a memory card.To the best of my knowledge the only cameras on the market which are guaranteed to be ready to shoot at the off, are disposable ones.
And a camera without a memory card is still a camera without a memory card, even with a lens nothing changes. It still can't take photographs. (Although no doubt some ar*e will point out that it could still be used to take a blurry image if you found a cunning way to convince the camera that it had a lens connected, presumably using pins, needles, a selection of resistors and some bits of wire).A camera without a lens is a camera body and nothing more and even with an SD card or a film nothing changes. It still cant take photographs.
look I'll say this only once it has a metal body not plastic ok!!![]()
Quite a lot of made-up b*llocks there, bolo, starting with you taking my statement out of context. A little run-down is due...bolo said:Softus wrote :"And digital ones that come with a lens and a memory card".
Wrong Softus. Only camera bodies come without a lens. The lens is an integral part of the camera. The film or memory card is the accessory which makes the camera 'fit for purpose'.
You get that impression merely because you've misunderstood. You're not the first, and you won't be the last. However, bolo, I admit to being astonished to see this particular piece of gibberish being posted under your user name.In studying your comments, I get the impression that you are the perfect example to illustrate, that the the power of the word, is in no way indicative of a persons faculty of reasoning and understanding objectively. And it would appear, that you do not have the common sense to compensate for the imbalance.
