Hi all
I've read through the sticky post on tiling and ready various other guides as I'm going to attempt to tile the full bathroom floor to ceiling shortly.
One thing that I'm not 100% on as I can't visualise how it should be is I understand setting the tiles out so you preferably have 1/2 tile or more at the edges of the wall to reduce small cuts and slithers. The part that I'm wondering about is would you use the other half of the cut on the adjoining wall or start from the centre of the next wall and work outwards again and finish the corners with another cut to reduce having a slither at one end?
I've seen many pictures where the offcut has been used on the adjoining wall so it looks like a full tile has been used so to the eye it looks the same length as a full tile. Although most these bathrooms have just been tiling 2 walls into an internal corner so if I did this once I get to the next corner I could potentially be left with a thin cut if you get what I mean.
Would having unequal tiles going in to the internal corners be an acceptable finish, the pattern will not be brick bond just in a standard grid finish.
If I'm making no sense at all let me know and I'll try to draw a pic to explain
