I contacted the seller and i was advised not to use a wet tile cutter but to use a manual tile cutter. The tiles are bevelled crackle glad brick tiles. Does that advice make sense to you tilers?
I plan to use Mapei Kerapoxy Epoxy Grout silver grey and a matching silicone to seal the gap between the bath and tiles as well as corner where the two tiled walls meet. Should I use the Mapesil Sealant or Mapei Mapesil AC 144 Solvent-Free Silicone?
