I wondered if someone could help me in understanding central heating pump curves? I am trying to make sure that an automatic bypass valve has been correctly set.
The boiler manufacturer requires a minimum flow rate of 1200 lit per hour.
Below is the manufactures spec for the pump:
http://productfinder.wilo.com/en/COM/product/0000002e00037bbd0001003a/fc_product_datasheet
Below is the manufacturers page for the Automatic Bypass Valve with the product installation instructions to the right of the page (downloads):
http://www.honeywelluk.com/products/...-Valves/DU144/
I am struggling in understanding how I follow the setting procedure on the second page of the Bypass Valve and the use of pump flow curves.
The pump is currently at 43 Watts and 6.3 head (according to the pump display) if that helps. Also the pump is in mode (Pump curves Δp-v (variable).
I also have the valve set to 0.35 at the moment, which I know is passing water on bypass (can hear the water noise).
I have read some of the other posts on this forum about turning the valve till you feel the pipe warming up, but that didn't work for me.
Thank you if you are able to help.
