Good luck with fitting a 3/4" ballcock and a 6" ball in a 18" diameter combination cylinder.As a general note. Using a combi boiler for a high pressure show only and using it to heat a low pressure combination cylinder with a 3/4" ballcock and 22mm cold water mains supply for the rest of the hot water is an excellent way. The 3/4" ballcock will ensure the integral hot water tank will be filled quickly. It is cheap, safe and reliable.
