There is a concrete slab in our garden which is very up/down. We want to turn this into a shed base with some parallel lines of bricks acting as bearers (one brick high). We also have a pile of bricks and sharp sand from a previous project.
In order to create flat lines of brickwork (bearers) on the dodgy slab base, some of the bricks will need to sit on around 60mm of mortar (where the slab low spots are).
Would it be wiser for us to purchase some building sand and create a 50:50 mix of sharp:building sand for the mortar? Or will using 100% building sand be a better bet in this instance. Our thinking is that the mix of sharp will be stronger for the thick mortar which will be necessary in the slab low spots.
