Shed electrics from garage electrics?
Thanks for the replies.
I'll try and answer/clarify the questions raised in your responses.
My Cu looks very much like this
http://aaelectricalservices.co.uk/images/Consumer unit replacement/MK5681ED17.jpg
Except that it does not have 2x Rcd's. Instead on the left side is the red main switch and then 6x Mcb's, then an RCD followed by 4 Mcb's.
The Garage feed is on the right of the Rcd (one of the 4 Mcb's) and the last Mcb is an unconnected 40a. I hope that makes sense.
For the shed I only require a single light and one double socket. The socket would be only for occasional use. Perhaps a battery charger, possibly an electric saw of some kind, plus I do want to add a small heater in the shed possibly a tube heater.
The consumer unit in the garage looks exactly like this
http://cdn.toolstation.com/images/130125-UK/images/library/stock/webbig/34579.jpg
It has in fact :oops: a 6a and 16a Mcb with a 40a Rcd Sorry.
I've just had a look at garage consumer units on the internet and see some 4 way Cu's have 2x mcb's and a main switch instead of 2x mcb's and an Rcd.
Could the Rcd on the garage Cu be changed for a switch thus leaving the supply in the main house Cu protected by the Rcd?
