Dang, I have just been changing our fluorescent lights for LED ones at work and we have not noticed any grinders looking stationary?
Don't tell me I need to put them all back now
...I also like the thought that should the light fail in the future I can simply replace a cheap tube rather than have to replace a whole led light fitting and have to re-wire it in again.
Be wary of 2d fittings, the replacement tubes are pricey & because of the compact design they run warmer than linear fittings. Common problem we got at work was the lampholder getting brittle and falling to bits (fittings were 10+ yrs old so not a big issue, annoying when the linear fittings on the grid were 30 years old and good as new)
Replacement 2D tubes are cheap as chips. Lamp holders going brittle usually only happens when they've been left with a tube in for a very long time that's had a starter stuck closed, meaning the cathodes have been glowing orange hot for hundreds of hours, baking the plastic
I don't like florescent because of the mercury content, but after trying led's as the main source in the workshop I went back to florescent because unlike led they also bounce light off the ceiling, the led are great above a workbench where you only need downward light.
They don't last long now either - including from supposedly decent brands such as Philips and Osram.
Have replaced plenty where they only lasted 6 months or a year before failing again.
Another thing that works surprisingly well is that LED tape fixed to a bit of batten (or the roof timbers if you like). Not sure about price per metre but light output is impressive
