I am helping an electrician do a power circuit to a shed, inside the shed there will be a lighting circuit and a power circuit.
I am assuming no more than two 100W bulbs (No fluorescents) will be used (probably lower) and there is 1 socket which will feed a clothes dryer (unknown wattage). But I am assuming the client will use this socket for power tools when needed.
Because I don't know what wattage the dryer will be I assumed it would be a 4kW meaning I need a 20A Type-B MCB for that circuit. But because I am also assuming he will use power tools in the socket when the dryer isn't used should I up this to a 32A MCB?
It is likely that the lighting circuit and socket will be on at the same time, so would I need to use a 32A Main double pole switch (or 40A if the 32A socket is used instead of the 20A)?
As for the feed from the Main DB inside the house I am planning to use an RCBO 30mA, will the rating need to match or be greater than that of the Main double pole switch inside the Shed DB? I am worried that the RCBO will cause nuisance tripping for all the shed circuits.
P.S. This was given to me as a learning task by the electrician I am working with
