Hi All
Looking for a bit of advice. Daughter has just moved into a bungalow, the place is split into 2 rings covering 4 rooms apiece. There is a shed she would like power to. The shed is just over 1.3 meters from the house, it's roof apex is 230 cm high and the house facia is 260 high. She won't be using any power tools in there, but would like a light and maybe the ability to use a small fan heater. So what I was intending to do is, break into the ring at a point nearest to the shed, put in 30amp junction box take the cable out from under the eaves across to the shed supported by a catenary wire, using a small pole to lift the cable at the shed end to the same height as the house. The shed by the way is about 6ftx8ft. The other point to make is that we are in Scotland not England. Forgot to say the cu has circuit breakers not fuses.
Are there any problems regulations wise to doing this?
The other question, is it ok to put the junction box under the loft insulation?
Many thanks for any help.
