Mine is in a cupboard on a shelf in our wet room but it's only about 20cm off the ground so could well not be a "shelf" as such and more like a plinth. I will see if I can work out how it was constructed.
18mm ply on 2x1s on 200mm centres. It is shelf-like in that it is not supported in the centre, ie, it could have been 100cm off the ground with other shelves under it.
But that's what's being suggested here - 3x2 at an extremely short span, sitting on ledgers mounted to the walls, with a thick plywood base - essentially a very solid floor
Makes sense to me; no kneeling on a cold hard floor to un/load the thing and very easy to put a bucket under the pump access panel if it needs manually emptying..
