Shock Arrestors / Mains water supply - Best Practice?
1 Oct 2011
West Midlands
Exploratory discussion about best practice for the ordinary home & Water Shock Arrestors:
Standard 3 bedroom semi detached house, water meter is on pavement out front.
Blue pipe comes into the house under alleyway.
Where (and how many) shock arrestors should be fitted in an average home.
I know some boiler manufacturers need one installed close to the boiler. But thats not what i'm talking about
I'm talking about protecting the rest of the system for in houses where the piping is old (e.g mine is 25 years - Copper).
Do any UK regs mandate/recommend water shock arrestors in the average home?
If so, where in the system (other than near the boiler) should they be installed?
Not needed and no, there are no regs that state arrestors should be used
Shock arrestors are mainly used where there may be sensitive components that could be damaged by hydraulic shock in the case of water hammer. The only other reason maybe where there is excessive mains pressure but that would usually be dealt with by a drop tight pressure reducing valve They are not designed to mask issues created by pipework and fittings that haven't been installed correctly, though that's one of the primary reasons they are used.
Properly clipped and maintained pipework and fittings shouldn't have any issue with dealing with anything that domestic mains can throw at it as most are spec'd up to at least 10bar, even at 25+ yrs
Yes, true.
However, in an old property, with unclipped pipes and unknown pipe runs, there may be a limit to how much investigation and invasive work someone wants to perform.
With the battle to gain A+ energy ratings, condenser washer dryers in particular, are notorious for their instantaneous intake solenoids cutting on and off the water continuously for hours on end; causing water hammer issues in homes that hadn't suffered from it previously.
It's not a great substitute for perfect pipework, but IMHO, local shock arresting of troublesome appliances can be worth considering.
So for a good installation they shouldn't be needed (other than when specced by boiler manufacturers).
I have pipework that is 25 years old. The kitchen an bathroom taps are lever taps, so the cut off is quick.
What different types of shock arrestors would the community recommend. Where should I put it / them.
Would it make sense to put it near the mains house stop-cock, if I am looking to protect the entire infrastructure of the house?
Certainly not suggesting they shouldn't be used but IMO they should be considered a last resort as there are other ways to correct water hammer issues rather than using a component to supresses it.
TBH as long as you don't have an issue with hammer then they are not needed. You would be adding a component onto a system that doesn't need it.
For the very reasons mentioned unfortunately I wouldn't be able to recommend a specific type as I haven't ever had the need to use them.
