So genetically modified crops are ok.
"Millions of pounds are lost each year by farmers because of rabbit damage and pigeon damage to crops. Grazers is a safe and effective spray against damage from RABBITS, PIGEON, DEER & GEESE."
http://www.grazers.co.uk/index.asp?m=1&t=HOME
Next
The stuff is horrifically expensive and solves nothing, it just pushes the problem somewhere else.
If it was so great every farm would be using it. Its a niche product for animal friendly gardeners, bit like using mole scarers and humane mousetraps. The b*****r will be back.
Edit: I suppose we could always go back to the widespread introduction of myxomatosis to control rabbits. Thats a lovely way to control rabbit numbers.
Same differencei think you confuse the words "kill" and "control" !!!!
Endorsed is one thing, actually being used is another. No farmer i know uses it.It's targeted at all markets including farmers and has been endorsed by some impressive orgs.
And who's consensus of opinion is this? Every landowner i have permission on is quite happy with the methods used.We are exploring your view, justification of hunting with your dogs and gun as a form of control. The facts don't support your view because it's the general consensus of opinion that shooting and ferreting etc are not effective ways to control rabbits.
Im fully aware myxo is still out there, im the poor sod that has to put the suffering rabbits out of their misery when they are wondering around blind.It's already out there and is carried by insects. There is also a new strain come from france that spreads from rabbit to rabbit.
Where do the rabbits go if every scrap of green is covered in this product? As some else has said, they will starve to death. Not very animal loving that.
Until someone comes up with a better way of doing it then its going to carry on.
Im fully aware myxo is still out there, im the poor s** that has to put the suffering rabbits out of their misery when they are wondering around blind.
Aaprotect, is the best with 95% success rate
According that pdf the best method of rabbit control is gassing. Would you rather i did that?
I like how you convieniently pick the sentances that suit you!
Chemical repellents
.....this advantage is lost if repeated annual
applications are necessary.... Only
treated parts of the tree are protected; untreated areas,
however close they may be to treated areas, are at risk of
damage..... Spraying can only be carried out between mid-
November and the end of February as the material is
phytotoxic to emerging foliage. Spring growth cannot,
therefore, be protected.
Here's a snippet from the basc
The rabbit
The whole of the UK, except the City of London,
the Scilly Isles, Skokholm Island, Jura and the
Outer Isles is a rabbit clearance area under the
Pests Act of 1954. The occupier of any land has
an obligation to kill or take rabbits on their land.
Failure to comply can result in prosecution or the work being done and
charged to the occupier.
http://www.basc.org.uk/en/media/shooting-the-facts-for-journalists.cfm
