Not only tradesmen. People aren't as bright as they should be.
In my mothers house the electricians cut all the conductors to exactly the right length to just reach each terminal, even though they used deep metal boxes. The conductors are so short you can only release the plate away from the box by around 10mm. It must have been so much work to connect them, having only just enough space to fit a screwdriver between the plate and the box. Every socket in the house is connected in the same way. The sockets are 45 year old MK ones so only a few have needed to be replaced.I find the short-sighteness of so many past (and present!) tradesmen baffling.
I knew a bloke who used to do £250 rewires in the mid eighties. Real tightwad.
He would put one socket in each room (where he wanted to put them), replace the light fittings in their original positions and a 4 way Wylex 3036 (1 RFC whole house, 1 lighting circuit whole house, 1 cooker circuit and 1 immersion).
He used to use Ashley sockets and they would be crammed in to 16mm boxes, because they were cheaper. He also used to try and save more cable by wiring up the sockets, screwing them into place then pulling back the cable under the floor, leaving absolutely no slack; this way, he didn't struggle as you suggest, Freddo.
Presumably no EIC.I knew a bloke who used to do £250 rewires in the mid eighties. Real tightwad.
I think that guy rewired my mother's house too.I knew a bloke who used to do £250 rewires in the mid eighties. Real tightwad.
The neon screwdriver won't light if they turn off the juice. . .The council never change. At a local property they did a 'full inspection and test' according to what they had written on the test sticker on the db. They somehow did it in less than 20 minutes, and without switching off the supply to the socket circuit!
About the time it takes to make and drink a cup of tea.They somehow did it in less than 20 minutes,
That would mean no cup of tea.and without switching off the supply to the socket circuit!
terminals are not always locate inthe same position on sockets and back in the day, very few sparks gave you any room for scope for alteration.
Maybe - but one would have thought that that whoever was doing it would have the common sense to realise the desirability of sensible length conductors - it hardly needs any 'training' to understand that!Its more often than not DIYers and other trades 'doing their own electrical work' that leave them too short to change sockets brands IMHO, because they can't dress the cores in properly
