Boiler cases are designed to be airtight at a few milibars. When there is ingress of water to the boiler then it will usually find its way through the seal. There has to be quite a lot of water though so I would definately get it checked.
'Seco Services' ~ No, I don't have a photo of the flue as I don't have a camera.
'Bengasman' ~ The Warm Front manager is due to ring me this afternoon. Thanks for the Gas Register number - I will ring them if Warm Front won't help.
'Namsag' and 'Simond' ~ I didn't 'let' the gutter leak onto the flue. I didn't know the gutter was leaking until I saw it on Thursday. The gutter is being repaired today.
'Powell30' ~ You say you've seen something similar. I'm scared to ask but was the boiler damaged beyond repair?
If you have house insurance then that will often cover the consequential damage caused by a leak.
There is a significant possibility that any damage to the boiler would be covered by your insurance as long as the boiler was correctly installed and we dont know that yet.
You have not said much about what your flue looks like, the slope and if the outside is sealed to the wall.
I'm not too sure what you mean as to what the flue terminal looks like. The end of the flue (as if you are looking at the hand on a clock) is pointing in between the 9 and 10. I'm sorry, I'm not sure how else I can describe it and hope you can understand what I mean? Is that how it's supposed to slope? It is sealed to the wall.
