just recently refitted bathroom and fitted a new 9kw Triton shower with 10mm twin & earth and a 50amp Crawford pull switch (nicely designed to help fit bulky 10mm twin & earth cable)
I then bought a Hager RCBO (CU is Hager unit) but noticed it was taller than the existing MCB's plus there is a thin 'flying earth wire built in.
Can I use the taller RCBO or should I just fit a 45 amp MCB since the CU is split anyway into zones protected by RCD's? (House was built in '99 and CU is of same age)
Cheers
Andrew
Cheers
Andrew
