Should I replace pipe insulation (asbestos?)
25 Oct 2012
Ive taken up the floor and found pipework below insulated with what looks like old rags (see picture).
Should I:
1. Leave it as is because its fine
2. Take all the old insulation off and replace with newer/better insulation (maybe the grey foam circular stuff that has a slit in it?)
3. Leave the current insulation on and get oversized grey foam insulation to put over the whole thing (so it would be pipe wrapped in old insulation then wrapped in new insulation).
Lastly - Will the old insulation contain asbestos and therefore be dangerous to hande?
Thanks!
Tom.
it looks like hair felt to me, any insulation big enough to go over that (leaving it in situ) is gonna be really expensive
take off the felt and insulate with the proper modern stuff.
It doesn't look like asbestos, as has been said probably hair felt, rip it off and replace with grey foam
it doesnt contain asbestos it is hair felt , just leave it be it hasnt burst in all the time it has been in so you dont have a problem
Thanks for the reply.
How do you handle the 90 degree bends and T junctions in the pipes when using the grey foam insulation? Do you just have to cut it and fit as best as possible, or are there T and L shaped foam insulation pieces available?
Thanks,
Tom.
