so its Golden showers you are having problems withEverything was golden from October
I'll wait for things to get worse before going there...so its Golden showers you are having problems with
I've just been on the phone with one of the installers (company called boxt) and that seems to be consensus as well, they say this is one of their most common queries.Your bath tap/ mixer is duff. Fit a new one. Preferably thermostatic
Duff only in that it does not take enough hot water from the boiler to allow the boiler to operate a continuous burn at minimum heat ( maximum modulation )
This is where I think something is a bit iffy with the shower - today, as the hot/cold cycle started, one of the things I tried was completely turning off the cold water tap, I then let max hot water run for a good 30 secs and didn't notice any more fluctuation. I then slowly started turning the cold water tap until it was a comfortable temperature and the temp remained perfect for the remainder of the shower.Duff only in that it does not take enough hot water from the boiler to allow the boiler to operate a continuous burn at minimum heat ( maximum modulation )
That could make the situation worse if the chosen temperature prevents enough hot water flow to keep the boiler "happy" cool.
BACK GROUND CALCULATIONS INVOLVED IN THE HEATING OF WATER
What is the OP actually getting though?
Do the maths.
Ok, tell me the flow rate, temperature rise and any boiler output settings and I'll try.
Worcester 30i combi
The parameters specific to the OP can only be provided by the OP.
If the input water temperature is known then the minimum flow rate necessary to keep the output water temperature below maximum can be calculated. If for any reason that minimum flow rate cannot be achieved and maintained then the boiler is going to cycle ON and OFF
