I've recently noticed the shower is alternating hot & cold about every 45 seconds or so. I've never noticed it before so think there may be a problem somewhere. Its fed via 2x 15mm pipes direct from the Combi boiler which was fitted about 8 years ago.
To test if it was the boiler causing this problem I ran the hot water tap in the kitchen sink which is next to the boiler. Its piped in 15mm from the boiler. I ran it full blast with hot water coming out then after about 45 seconds the boiler shut down for about 5-10 seconds and the water went luke warm then it fired up again and I got hot water again and the cycle repeats.
The boiler is an Ariston microGenus 27 MFFI and changing the water temperature setting on the boiler doesn't seem to have any effect.
Is this a problem with a boiler thermostat ?
