Shower/bathroom panels
11 Jul 2015
Hi
Having a new bathroom
Thinking of getting the whole of the bathroom walls done in panels.
Is this a good idea?
What makes are best and type, thickness etc.
are there any bathroom chains that have good stuff? Easier for getting the edging etc if short.
Thanks All
There's a fair bit of choice out there and it's really a job for an experienced person but I've used MultiPANEL a fair bit....9mm thick, has a balancer laminate on the back and all of the corners in anodised aluminium are available. It cuts well.
For sure it's expensive but you only do the job once and the finished effect is wonderful.....easy to clean too!
It doesn't accommodate angular corners other than 90 degrees though so this has to be considered if you need to box pipes in or whatever.
I took the opportunity to space the product off the wall so I could run all of the service pipes behind - including using a semi pedestal basin.
Tiling? A thing of the past :whistle:
John :)
