- Joined
- 17 Aug 2010
- Messages
- 2,888
- Reaction score
- 506
- Country
I don't think we yet know the power rating of the shower either. 32A may not be sufficient.
So, I can freely turn it off and on after using it, I try it several times throughout the day and after using other things in the house just to see if it’s triggered anything. It doesn’t seem to trip immediately after switching it off, ever. It just randomly trips at some point during the day/night/morning.From what you have told us ,I suspect what is happening is when you switch off the ceiling pull cord switch ,that is when the MCB trips. When you next go to use the ceiling switch nothing works ,as the MCB is already off.
You could check the MCB , after switching off the ceiling switch ,each time shower is used. If it is tripping the MCB as described ,that points to a suspect ceiling switch ,possibly the MCB.
You will at some point need to engage an electrician to test and rectify.
Don’t even get me started on the electrics in this place! Everything is daisy chained off of something else apparently, and when I moved in and tried to change the wall lights in the living room (alongside the garage) found out they had been hard wired straight into the mains - thankfully that got sorted out but I have a feeling there’s a web of lies behind the walls!Nice to see some cowboy crowbarring a “foreign” MCB into a different donor consumer unit.
always points towards someone with a make do attitude. the quality of the installation may prove to be the root cause of this problem.
Scratch that, had a brainwave and looked on the underside of the unit facing the floor and it seems to be the 9.0kw model.Don’t know how to find this out without a manual for it (assume my grandad ‘filed’ it away somewhere before he died so safe no human will ever see it again!). From a look online, I think they made this shower in 9.0 and 9.8 kw. Would this sort of fault just start happening 7 years (possibly more) after installation if it wasn’t fitted correctly with the right rated board? Or would it have always happened?
I get the impression it only trips with the isolator off. I'm still suspecting a faulty switch.Unless I have misunderstood, the MCB can trip even when the isolation switch is off.
@Rhibhi85 can you confirm?
The usual obvious fault location is in the switch itself. @Rhibhi85 have you looked in there? Power off first please!!
