- Joined
- 19 Mar 2007
- Messages
- 715
- Reaction score
- 5
- Country
That’s unusually wide for a wall, particularly in a shower cubicle & may have contributed to your problem, see below.thanks pal - bal grip or whitestar, either will do....im just wondering if i should stick with the same tile spacing as it is because the grout lines are 6-7mm...
It’s important to remember that waterproof adhesive & grout (except epoxy) is only waterproof in the sense it wont disintegrate when it gets wet, it will still absorb moisture & is why a waterproof tile base is important. It’s also advisable to stick with tiling products from the same manufacturer.it is water proof so will have to do
Look as good as any, just make sure you put enough of them in.what plugs are best for securing the battons onto the thermalite blocks in the wall of the shower ?..i was thinking of these below should be strong enough to support the weight of the boards and the tiles...or not ?
