- Joined
- 11 Jun 2016
- Messages
- 2
- Reaction score
- 0
- Country
Hello, I am really after some help, I recently installed new mixer taps, and a new overhead "rain" shower, you push the centre piece DOWN (where the shower tube connects from the tap, to the shower) to activate the shower. However, once I turn the taps off, it doesn't seem to reset the switch, so once the taps turn on again, the shower comes on (and gives a bit of a shock when not expected) if I remove the pipe from the tap, a lot of water pours out, making me think its a pressure issue. I have turned the water cut off valve down to limit the intake of water (I'm a complete novice) but no effect. I'm guessing (and this really is a complete guess!!) that the water pressure remaining in the shower piping is enough not to allow the tap to reset. without physically removing the pipe from the tap and manually draining it. any help or ideas would be gratefully received.
Kind Regards
Kind Regards
