Hi everyone .....quick question:
I've been noticing an unpleasant fishy smell in my living room when i use my new shower I've googled it and I've come to the conclusion that it must be the fuse burning, as you can also hear a slight buzzing near the fusebox when the shower is on.
My shower is 9.5KWh made by Gainsborough and I only had the shower engine replaced, as the heating element in my older Gainsborough shower broke. Anyway, the older Gainsborough shower was also a 9.5KWh so I assumed all the correct cables and fuses would already be in place for the new 9.5KWh.
There was no info or instructions supplied with the shower as it was a replacement part. Can I just upgrade the shower fuse in the fusebox to a 45 fuse? Is it as simple as that or does there have to be special wiring for it?
Thank you for your help
