shower overheating at consumer unit!!!
phil_b Have a look here All the graphs to frighten you, and more are in these pages.
Has Mr Whitfield, in his Note on Supply Voltage Level, described another rip off in the making ?
P
Why does a brown CU need replacing, it could well be a modern one with RCD and MCB's in it- colour doesn't matter.
brown generally means very old wylex standard
the newer wylex standard boards are white
actuly it means bakerlite
they still make stuff in brown- but not in domestic wylex(that ive seen)
and weather they are white or brown or blodey pink- rewireable fuse boxs should be replaced, there is no good reason not to.
by the time you buy all the plug ins, then fit an rcd upstream of the board- which gives you no real discression- have fun splitting one of em
even if that dont matter you soon end up with a rats nest
ZenStalinist said:
CORGI website said:
93% of gas work carried out by non-registered installers has been found to have serious safety defects.
Surely that should read "93% of gas work carried out by non-registered installers where something went wrong and an inspection was carried out has been found to have serious safety defects."?
How can they possibly know how much non-registered work is done that is perfectly OK?
