Hi, and thanks in advance.
My shower that I fitted neally a year ago now has started to ''play-up''
At first I thought it was the switch, maybe a loose connection. I removed the switch and put it back on. There was no loose connection, however one of the nuetral cables had a black kind of sut on the end, where the connection would have been made. It worked fine for a couple of days but this morning my girlfriend was in the shower and it went off. It hadn't tripped in the consumer unit, we just turnued it off with the pull cord and then back on again 10 seconds later, it worked fine, and continued to wrk fine while I was in the shower. Is there a fault with the shower or the switch. I used the correct breaker and size cable when I installed the unit, so I don't think it's them, Like I said, it's worked fine for neally a year now.
Any ideas?
Cheers.
Any ideas?
Cheers.
