Shower hot water not as hot as bath tap...help needed
Is there a guide on how to remove the cartridge. I don't want to start something without first having some idea of what's required for obvious reasons!
Cheers
Daz
Cheers for that. I'll assume the cartridge is in the temperature selector and not the valve above?
Once I have the chrome cover plate off I hope to find some isolating valves but if not I think I have them at the pump end.
Yes the bottom valve. The top is a flow cartridge.
No the shower mixer has no isolation valves you'll need to isolate the pump etc.
Also clean the filters non return valves, they are located each side of the temp valve.
Well I've turned the pump power off and shut off the hot & cold water feed valves to the pump yet I'm still getting water out of the shower head....how?
G-d forbid the plumber should have fitted valves to the output of the pump! Mind you, that would have cost him a fiver!
Thanks for that. It would appear that half of the cartridge is stuck inside the manifold and I'd rather not make the problem worse by pulling hard with pliers to extract. Can I immerse the half that did come off with One Shot or do I need to get the whole thing out?
Things have gone from bad to worse now. I removed the NRV on the left to see if it clogged and to be honest it wasn't that bad but I gave it a clean anyway. Put everything back and now I have no hot water at all, just cold. Anything I can do?
