- Joined
- 25 Oct 2013
- Messages
- 2
- Reaction score
- 0
- Country
Good morning all. I've just replaced a set of separate bath taps with a cheap shower mixer as we're about to gut and replace the other room with the only shower. Been running a few tests and it's proving very hard to get a comfortable temperature balance, which I gather is normally down to having poor pressure from the hot tank.
We've got a combi boiler do the whole hot system is at mains pressure, and the cold for sinks and showers is from the tank. We've always had really good hot water, and other than humming quite loudly, the shower mixer has always been brilliant. However, I've found that on the two tap mixer it's fine in bath mode, but on shower mode as soon as the cold is turned on the pressure vanishes and all the hot water crossflows into the cold system (hot water at cold sink taps!).
While a check valve on the bath feeds would solve the crossflow problem, do you reckon it would allowthe temperature to be comfortably balanced? it's only a temporary fit so I didn't go all out with a thermostaic tap, and I'm concerned that fitting any type of prv would deny the benefit of having a combi boiler for good hot supply... I'm also this might become a problem when it comes to replacing the original shower valves which have worked well.
