Hi, I have just boarded out my bathroom, the area where the shower is going to be had 12mm Hardibacker board over a stud wall. The studs are 400mm centers. I put noggins at the half was point between the floor and ceiling.
I'd quite like to add a 'shower niche', or recessed shelf. I used 2 x 4 for the stud wall so I have quite a bit of space for the shelf. I'm looking at these:
https://www.ebay.co.uk/itm/Thermopa...FAuE3UctJEEtZYvD_mZw:rk:1:pf:1&frcectupt=true
I still have access to the rear of the stud wall which is not yet boarded so I can access the whole of the inside of the wall from behind.
I am thinking that all I'd have to do is make a hole in the Hardibacker and then put 2 more noggins, 1 above the shelf and 1 bellow to support the shelf. I can pack something in either side as well to effectively 'box in' the niche.
Is this easy enough to do? Is it worth the hassle? The niches I am looking at done have a 'lip' on the front, the front of the niche would be flush with the face of the hardibacker board. Would I need some sort of waterproof tape on the inner sides of the niche folded out onto the hardibacker to seal it?
