Hi Guys,
I have finally decided to get a pump installed. It is a standard gravity fed system with Cold water tank in loft and hot water tank in airing cupboard [same floor as shower].
I have had two Plumbers around to quote me on the work.
1. Suggested installing pump in airing cupboard and then piping it to loft then back down to shower.
2. Suggested installing pump in loft with no additional piping
Option two seems less messy and the plumber did say that the pump will be slightly expensive.
Any ideas which is best way forward and what sort of pump I should be looking at.
Work will be done by a professional plumber but I have had no previous experience so I want to gain some knowledge and ensure it is done correctly the first time.
thanks in advance
thanks in advance
