Mrs might have something to say about toilet filling slowly but hey I will just sleep in the shed when it comes to it LOL
Supplies need to be balanced and dedicated to the shower. If you are correct and have an unvented cylinder, then I'd have expected any draw on the cold supply should be affecting the hot and cold supplies equally.
Quite. That's the obvious answer.Precisely, and I'm guessing his shower is a simple mixer shower, rather than a temperature controlled mixer.
The shower looks very fancy so I'd have thought it would be thermostatic, might be worth studying the manual and perhaps speaking to the maker to check whether it should be. If so maybe the cartridge has failed and can be replaced.
If it's just a mixer, and another cold water outlet is opened the cold to the mixer falls. And if a hot tap is opened the shower would go colder. Might be worth the OP checking whether the effect is the same when any tap is opened.I agree, but it still doesn't explain why there seems to be a difference in flow, or pressure, between the hot and cold.
