Shower tap is stuck, won't turn
13 Dec 2014
Please help in finding ways to make my shower tap work?
At the moment the shower is much too hot to stand under. This is because
only the hot tap works. The cold one is stuck.
I suspect it may be limescale. I live in Luton, where the water is known to be very hard.
Ive only just moved in to this rental flat.
Can I somehow squirt descaling liquid into the gap of the tap?
Sometimes taking the cap off and spraying WD40 works, although it's a temporary solution.
It's the unfortunate reality of hard water areas.
Erm, confused. I presume the shower turns on? That's a bar shower, the control on the left turns the water on and off (probably 1/4 turn) - the one on the right alters the temperature. Turn the shower on, left, then turn the right hand one away from you and it should go cooler.
Rental flat = landlord problem. He/she has an obligation to provide hot and cold water services and heating (as well as various other services). I'm a landlord (well, my wife is, I just do the work), and my reaction would be to change the whole bar shower. New Bristan is about £110, and can be fitted in 20 minutes provided water can be turned off. Note that the landlord is not obliged to provide instant repair, but is obliged to do so in a reasonable time. Same as if it were your place and you had to find and hire a plumber.
