I have an 10kw electric shower which is run through a double pole pull switch which is connected to an individual 40A MCB + RCD box connected direct to the meter. All cables are 10mm.
About 2 minutes after the shower is switched off the MCB trips. A new shower has been fitted and still the MCB (not RCD) trips. After fitting the new shower I've discovered the MCB trips even if the double pole pull switch is turned off immediately after the shower.
Any suggestions greatfully received.
