Hi just removed the old shower 8kw on 6mm three core wiring and was going to fit a 9.5kw shower ,10mm three core cable and 45amp fuse. Couldn't get the cable out of the wall so can I fit the new shower, the thing that is confusing me is the charts for the power rating of the cable,my cable is just under the surface and only 2m from the fuse box, or should I go back and get a lower rated shower unit, if so will 8.5kw be alright on the old spec wiring? Thanks Nardoblue
